1 - 8 of 8 Posts
· Registered
just fitted a new clutch and flywheel today and im a little bit worried with the result , i fitted a exedy fast road organic clutch and fidanzer ally flywheel and it s a bit of a bitch to drive ,its very difficult to take of smoothly and it judders when you change gear does this sound normal , hope your gonna tell me its ok thank you. :confused:
· Registered
An organic clutch and ally flywheel should not be difficult to drive as long as properly fitted - suggest you get it checked.
· Registered
Spoke to a couple of guys at steve hills today they agreed that it should drive pretty mutch like a standard clutch :confused :( the only thing they could advise was to slacken off all the engine mount bolts and re tighten them ,due to how i tightened them i could have loaded the mounts up ,other than that it could be a warped plate im 99.9% sure that every thing else is right ,on my short drive home it seems a little better hoping it will get better as it beds in.
1 - 8 of 8 Posts
