Does anyone know what the difference is between the AP organic plate and the standard clutch plate, such as the frictional qualities and thickness. I know the diameter is the same at 230mm. I'm not on about the cover as the AP is obviously uprated for a stronger clamping force.
The reason being that Alcon will modify the standard cover for a stronger clamping force without increasing pedal pressure and If then it is used with a good organic plate the setup should be similar to the AP kit but for about a 3rd of the price. Unfortunately Alcon can only supply Paddle cerametallic plates, thus the question above.
Clive
