1 - 3 of 3 Posts
I have this issue on my evo 4 where the clutch pedal drops slightly but
You can pump it up and it will be fine then it will drop slightly again. I've changed the clutch and clutch slave but it still did it so i changed the clutch master and it still does it. I'm at nurburg ring now and bled the master out by pumping pedal and cracking off the union then i did the same with the slave but again it still drops slightly. Really odd
Well assuming you don't have any hydraulic issues, it could be crankwalk. Check the crank end float - if the clutch is dropping, it might be possible to actually see the pulley move when you put your foot on the clutch.
Cheers,
Simon
Thanks i just had a look now and looked ok but a mate suggested looking at the rubber hydraulic clutch line and it's swelling up abit so i'll order another
1 - 3 of 3 Posts
