1 - 10 of 10 Posts
driving along the motorway today , i noticed my clutch starting to slip at high revs . so this is a post to see what type everyone recommends . I would also like to know how much this should cost from a main dealer or other garage. ive looked at older threads on this but i would like some new info. do you also recommend changing gear box oil or anything else at this stage?? thanks
john
Depends on yr personal preferences.
Do u want a clutch that provides the same driving characteristics as the factory unit but with higher torque capacity , if yes then avoid metallic , paddle or puck clutches and go 4 a full face carbon/organic , sprung centre clutch.
If u can handle less user friendly clutches , that is more difficult in traffic , reversing and know how 2 avoid overloading the drive train with full on starts , then u can go 4 non-sprung centre twin plate or paddle units. These will handle almost all the abuse u cud throw at them.
Negri,
Go 4 the AP organic unit , £350'ish |PLS| fitting.
Check the flywheel carefully 4 cracks or scoring b4 fitting the new clutch.
is the flywheel meant to be changed at the same time ?? and the gearbox oil ??
now got the car booked in to don buckley in kelso , says he will look after my car once he is back from a rally
Negri,
The flywheel needs replacement if it is cracked or scored , just have yr garage check it carefully.
All trans oils (gearbox , transfer case , rear diff) shud b changed at 12k miles on normal road use or 6k miles if used on lots of track days , ie more than 1 per month.
The AP organic clutch is just fantastic, i've just fitted one along with
a JUN superlight flywheel and the differece is *VERY* impressive;
I can sell both of these parts at a fat discount, so mail me if I can help.
May as well change the gearbox oil whilst your at it;
a **** hot mechanic can do the lot in less than 4 hours,
do check first, as some garages will try and charge you a days labour to
fit a clutch/flywheel !
Justin Foden
www.torqueic.com
Yellow,
any roughness at idle with the lighter flywheel?
BTW how much lighter is the Jun unit?
1 - 10 of 10 Posts
