Discussion Starter #1 (Edited)
i've got a LHD evo7RSII with as new coilovers and ralliart top mounts, both fitted 5 months ago without any problems so far.
since a few days i always can hear and feel a slight clonking noise from front left corner, only at very low speeds driving straight ahead or in left corners, over very small bumps, not in right corners, when there is more load on the left wheel or when driving faster.
garage checked wheel nuts and struts, everything seems ok.
couldn't find anything on that sort of clonk with the search option.
please, any ideas?!?
get it occasionaly myself ,make sure there is plenty grease on top mounts, check drop links ,get used to it, nature of the beast,seems to be a common gremlin.
two to check:
Spring is sat correctly in it's cup and to the stop.
Top mounts have been installed correctly and the plates+spacers are in the correct order - else the top of your spring can twist :eek:
Those who were at the last sprint saw what can happen when the latter is then given some abuse :rolleyes:
Discussion Starter #4
thanks, mates!
will check these points again.
