Noticed when I had the windows down the other day a clinky tinky noise comming from under the car as I power on / off or change gear. So under the car today I can simulate what I assume is the same noise by rotating the prop slightly, as if there is play in the center CV (type thing) in the prop, is this normal and I've just never noticed it?? or does the joint need replaced??
