How do you check the fault codes on a e7 I've tried the jumping of pin 1-4 but would show any engine flashes at all and evoscan won't connect to check any codes with a tactrix 2.0 cable
You can check other codes (ABS/ACD/AYC etc ) with the pin out method ...but you do need evoscan /diagnostic tool for the engine codes for 7 onwards ....
Maybe dodgy lead ? Or are you making any connection at all ?
got a loan of a diagnostics tool in the end was hoping id have a fault to explain the misfire
Wont always get a fault shown though , if you have a misfire then start with plugs , then coil packs n leads .....:thumbup:
