Hi Guys,
Fitted my De-Cat pipe last week:D Car seems to be more responsive now and suprisingly alot louder!.
Anyway what should I do with the sensor?. I disconnected the wires but that resulted in a light coming on on the dash, Should I just ignore this light or reconnect the sensor and tie it up somewhere?.
oops, sorry I just realised I posted this in the wrong section:(
Thinking a similar thing myself. As I see it there are 2 options:
1) The light is on because of an open circuit - close the circuit and the light goes off.
2) The light is on because of a closed circuit - break the circuit and the light goes off.
However, many years of Mits ownership tells me that it might not be quite that simple..... :)
Mines just taped up out of the way. But I get no light on the dash.
Evo's must run an different circuit or the dash bulb has gone :)
TonyC
Thanks guys,
I checked to sensor and it's a normally closed circuit. So I guess just looping the 2 wires together will turn the light off:D.
I made the cat by-pass myself, easy when you have the gaskets for a flange template. Which also answered the question if the 1800GSR and EvoII exhausts are the same, Well they are exactly the same from the turbo elbow back because I also made one for Steve's Evo II.
Tony
Any luck with your car yet?
