1 - 2 of 2 Posts
Hi all,
I got the geometry set up on my Evo 7 last October. Everything was fine until I changed the front 2 tires after christmas. Since I have put the 2 new tires on, the car is pulling a bit to the left.
Has anyone any ideas what would cause this. The tire pressures are Ok. The rear tires are on the thread limit and need to be changed. Would this throw out the geometry, having 2 new tires on the front and fairly worn tires on the rear.
Phil
I had a similar issue recently and tried swapping over the fronts. My tyres were pretty worn so that probably explained why it did the trick for me. It shouldn't make any difference with new tyres, but if it does then you know that at least one of the tyres is faulty.
1 - 2 of 2 Posts
