1 - 5 of 5 Posts
are the tommi mak cams different to v gsr cams please OR could v gsr cams be fitted to a tommi engine? please Possible or poss but no good?
Poss problem solver:smthumbup
#armchairtuner
evo 4 to 8 all use the same fitment cams so they can be swapped around. Not sure if there is any difference between V GSR and Tommi ones in terms of performance.
evo 4 cams are different to 5 on , mak cams same as gsr /rs , evo 8 mr cams different again.all interchangeable but 7 on cams have a different cam sensor bolt and sensor cyl , if fitting 7 on cams to earlier models drill the sensor cyl and use 7 on bolt. 8 mr cams better than the rest .
1 - 5 of 5 Posts
