1 - 20 of 24 Posts
· Registered
The transition from PGR2 to this isnt as easy as id thought! This is alot more realistic.
Ive set top 200 times on xbox live but cant get near you lot on this! yet!
· Registered
its totally different though!
plus the cornering speeds in GT are alot more realistic. License tests for me this wknd!
· Registered
Pads for me. I don't really have the space for a wheel (at least not for a wheel for the console anyway), and unlike Andy I can feather the throttle just fine on the pad :D
Since I'm generally belting around at maximum speed I rarely have to use less than full steering lock as well, so I'm not sure the investment in a wheel would really be worth it.
PS DaveR, lift-off oversteer is generally a feature of cars that understeer under acceleration ;)
· Registered
Am I going wrong in trying to drive it and preserve my tyres? ie, no squeal as im cornering. Or should I just wang it round going from lock to lock!? lol
What wheel is the weapon of choice?
After using an xbox pad for so long with the triggers for brake and throttle its hard switching back to two buttons. You cant trail brake easily, its not too easy to modulate the throttle either. (Maybe the pad is ****ed?!)
· Premium Member
Buttons for me for car games
Sticks for planes :D
I sold my wheel as it was a bit too vague
Jez
· Registered
Buttons? The default GT4 pad configuration has the left analog stick for steering and the right stick for acceleration (up) and braking (down). Much more finesse than buttons or triggers :D
Oh, and I spend most corners finessing the throttle because the tyres are always giving way. I'd say wang it round lock to lock and steer with the throttle. Works for me ;)
· Registered
Discussion Starter · #18 ·
Only prob with the right analogue stick is that you cant brake while still on the power!
Ill give it a try tonight. :)
1 - 20 of 24 Posts
