I will be breaking my CTEC Evo 5RS - 2.3l GT3076r 17,000miles at the end of next week.
There are some top spec parts and I am sure it will create a lot of interest.
http://www.lancerregister.com/showthread.php?t=422796
Engine
Evo 9 Mivec Engine
Mitsubishi 4G64 100mm Crankshaft
JE SRP 2.3 Stroker Piston Set 85.5mm
ACL Race Rod Bearing Set
ACL Race Main Bearing Set
ACL Race Thrust Washer
ARP MSK
Specialist Block Maching (Rod/Block Clearance & Crank Breather)
Short Motor Balanced
Deck & Rebore With Torque Plate
Cosworth Crank Scraper
Crank breather system
Kelford 272 Mivec Cams
Ferrea 6000 Series Inlet Valves - Std Size
Ferrea 6000 Series Exhaust Valves - 1mm OS
Ferrea Dual Valve Springs
Ferrea Valve Collets
Ferrea Ti Valve Retainers
Ferrea Valve Spring Seat Locators
Ferrea Valve Stem Oil Seals - Inlet
Ferrea Valve Stem Oil Seals - Exhaust
Gates Racing Kevlar Cam Belt
NGK ILFR7H Spark Plugs
OEM 9 ECU on Speed Density (Mapped by Jamie @ Evotune)
AMS GT3076R Turbo Kit
Turbosmart 38mm Ultragate Wastegate
AMS Slimline 10" Radiator Suction Fan
Koyo Rad
Walbro 255L/H Fuel Pump internal
Bosch 044 fuel pump external
Swirl pot mounted in boot
RC 1000cc Injectors
Sard Fuel Pressure Regulator
Oil Catch Tank
3" Simons Silencer (Replaced De-Cat)
Blitz NUR Spec R Cat Back
HKS Type S FMIC
Odessey PC680 battery
AMS Upper I/C Pipe & Tial 50mm BOV
AMS Lower I/C Pipe
Turbosmart Ultragate Wastegate
Custom 4" Inlet
4" Neck ID K&N Air Filter
Gloss Black Mivec Rocker Cover
AMS Brushed Plug Cover
Drivetrain / Running Gear
C-TEC Ohlins DFV - Custom valved by Aurok
Whiteline adjustable drop links front & rear
Superpro Poly bushed (See feature in Evolution Mag Issue 1)
RS Gearbox (Medium 155mph)
RS Diffs
RS Transfer
Exedy Twin Plate Clutch
AP racing 330 Front Calipers (CP5555)
AP racing CP5555 Disc (New)
Brembos Rear
Mintex F4-R Pads (New)
Perrin Anti Roll Bar
8.0 x 18 Ultralite G Grid
Interior
Recoro Bucket Seats
SPA Design Gauges
Solid State kill switches internal & external
Manual Fan switch
Sparco suede wheel
Cusco Bolt in cage
Exterior
Carbon Mods Front Splitter
Rallytech Carbon Door Mirrors
Clear Evo VI OE Front Indicators
Clear Side Indicator Lenses
Aluminium Rear Spolier Blade
The car also has a brand new set of team dynamic pro race wheels fitted that have done less that 100 miles and are as new.
I can also be e-mailed at [email protected]
Engine
Evo 9 Mivec Engine
ARP MSK
Koyo Rad
RC 1000cc Injectors
Oil Catch Tank
HKS Type S FMIC
AMS Lower I/C Pipe
Custom 4" Inlet
RS Diffs
RS Transfer
Brembos Rear
Interior
Recoro Bucket Seats
SPA Design Gauges
Manual Fan switch
Sparco suede wheel
Cusco Bolt in cage
Exterior
