1 - 3 of 3 Posts
· Registered
Does anyone know if you can move the standard brembo 4pots at the front to the rear??
Can you still get the spare tyre on?
what are the largest AP 6 pot kit / disc size possible for the fronts for the standard 17" enkeis?
· Registered
Not a good idea as you will need to increase the master cylinder size to pump more fluid in to system. (the AP 6 pot kit has a similar fluid volume as the Brembos. But it is probably possible to make them fit if you want !
No the spare tyre will not fit over the Brembo 4 pot caliper (or the AP 6 pot) But will fit over the AP rear 4 pot. I have tried !!
332 by 32 for the standard 17" wheels and 362 for 18" and over
1 - 3 of 3 Posts
