1 - 3 of 3 Posts
my rear pads are u/s fronts r still original i think because they r the same colour as the calipers, and still seem 2 have plenty of meat on them.so why have the rears worn so quickly i then realised the cars lowered using eibach springs. so i am wondering if the bias has not been adjusted 2 compensate the lowering thus wearing the rears also there is more brake dust on the rear wheels. does anyone know anything about this and wear the valve is my concern is this may cause the rear 2 break away under braking not good:)
The brakes are diagonally split, so you cannot adjust the bias anyway.
Most of the braking on these cars is done at the front, so this seems a mighty peculiar situation you have here.
the pads i removed were green maybe g force. some of the writing had rubbed away, must be very soft and wear quickly thats all it can be thanks 4 puttin me straight with the bias bit
1 - 3 of 3 Posts
