1 - 3 of 3 Posts
can anyone tell me if it's easy to change the gearbox oil on the E1 i'm going to atempt it tomorrow but i'm not sure if it has to be pumped in/out or drained any advice would be appreciated, thanks :D
Yes, a bit of advice. Remove the fill plug first, that way if the oil is drained and you find that the fill plug is stuck in the box you will not be stranded.
2) if you want to be really tricky you can fill the box from the breather on the top of the gearbox. It makes for a less messy effort if you don't have the right tools.
-Alex
Hardest thing is getting oil back in the damn thing!.....access near fill hole is restriced by rad hoses and fan but you can get a little bottle in...often need a litre more than box takes as it hard to get it all out of each bottle due to angle you need to work.....if you can get a pump it would be easier but not essential.
Ian
1 - 3 of 3 Posts
