and amp;lt;rant and amp;gt;
living in nz as i do i'm going to come to this guys defence, the question seemed to be how high can i run and various responses were made
then the question was asked what happens if you turn it to 100
then trent replied that he has run as high as 80
then the next line what he was actually saying was too the effect of don't do this unless you can afford to replace your motor ie its not a good idea for the long term health but at least for a short period it has been done
a culture difference in the way things are said
and calling him an idiot was uncalled for
max boost in a 6 in nz tuning circles on standard pistons is said to be 1.8 in fact rods the weakest link will fail somewhere between 375 and 400hp, which means you cant run this boost higher up in the rev range as u may get rod failure
so this boost controller is a waste of money as not capable of tapering the boost properly and your car is slower than it could be
obviously in a 1 or 2 then safe boost is lower as pistons not as good, a common budget mod is to fit 6 pistons with vr4 rods, vr4 rods said to be good for up to 450 hp, but are heavier so engine response not so good
nz has the second highest number of evos after japan and the lower numbers are very common as there are floods of them coming in used from japan, you should encourage these guys, might learn something
also sticking a pe (or any other ecu) in your car will not allow you ALONE to safely go over 1.3 bars, the reason being that the fuel system can't cope and needs to be upgraded too, it can't supply fueling for fuel that isnt there
i agree though, for calling someone an idiot then you should be banned
last but not least, if someone went hahaha after a post i'd made i would probably think they were a ****** too
and amp;lt;/rant and amp;gt;
