1 - 5 of 5 Posts
Hi, you need a boost controller, a cheap,but good option is a Dawes boost controller, this is a ball bearing type mechanical controller.
Otherwise, electronic boost controller, like Apexi AVCR and others, blitz etc. will give you in car control over your boost.
An uprated free flowing air intake, and exhaust with decat will also increase boost due to freeing up the breating of the car.
Your limitation will be the fuel cut, at about 1.3 bar, and an uprated fuel pump is always recommended
Do searches on here under the forum tab for :
Dawes
AVCR
Fuel cut
should give you loads of info
Stu
1 - 5 of 5 Posts
