1 - 9 of 9 Posts
Hi,
I'm putting in a Gizzmo MBC and was wondering how people have been getting the boost pipe to the solenoid? Car's an Evo 5.
There's a small hole at the top left of the bay which is used already for a amplifier wiring kit positive cable and the boost gauge wiring (its a plasma gauge)
I want to drill as little as possibe and in a place that will not risk damaging anything.
Any suggestions appreciated.
Thanks!
Regional Organiser
Where abouts in the car are you trying to mount the controller mate?
I put mine through a bolt hole in the drivers side inner wing and then into the cabin from there through a wiring grommet, comes in just over the accelorator pedal. All behind the plastic arch liner outside.
I'm putting the controller above the stereo in the centre of the dash in the top half of the double din slot.
I was looking for the best place to drill, or any hidden grommets I havent found like Graham182's suggestion above.
Thanks!
I tried this Lee when i fitted mine and there was no gromet under the arch liner.So had to fit it through main loom gromet.. Is it only on driverside?
1 - 9 of 9 Posts
