Guest
·I not really sure that you have made the right conclusions Shorty. My car makes about 370 Hp on high boost. I still have standard internals and turbo. So from what you are saying my car should be shagged. Well still goes like a good en. My high boost setting is 1.6 bar. Only differance is that I have a Ralliart ECU to dump more fuel in at high boost. I also have a uprated fuel pump to enable the fuel to be pumped out at these levels.
My car could make more but as I have said before the injectors are almost maxed out so you really need larger injectors to safely run higher boost than 1.6 bar as you car will start to lean out.
Thorak
Just my 2p worth.
Thorak
Just my 2p worth.
