1 - 2 of 2 Posts
what gain setting is anyone using ?
my understanding of it is that if you have traction problems,i.e. 2wd
you would need to lower the setting
but as we have 4wd does it not want to be on 100 ???
I'm using between 30 and 40 depending on the temperature. I have the SBC-iD but it is basically identical to the DSBC, except for speed mapping. You can adjust your boost if you look at your boost gauge and check if the needle starts vibrating when you build up boost. If that's the case you are running too much gain. Like I said before this is due to the turbo physically not being able to hold the pressure curve that the boost controller is executing. Don't run 100!!! Although a little too much gain is not bad for the internals, I'm sure going that high up will do something to your turbo
1 - 2 of 2 Posts
