Hi!
I would like to know the price of the rally tech airbox, and where did you get the alloy pipe to fit it?
Was it made by power engineering? Can you please me send the informations about where to buy the alloy pipe and hoses to fit it with the standard air flow m and blitz filter?
Thank you
Maxi
From memory, I think it was about £230. The airflow meter is in the box itself, and a panel filter is used at the opening. You can get a K and amp;N induction filter, or small blitz instead instead if you prefer, but the panel works well. PE made all the piping, based on the stuff from the SPEC-R boxes they sell. Normal big blitz filter won't fit.
Box was designed for a piper airfilter, no airflow meter (map sensor instead). Bugsy has this setup.
do you know if you can order the rallytech airbox directly from pe with all the necessary fitting items as the blitz filter, the piping and hoses? Price of the piping?
