Hi All,
On other car marques you can usually kit kits that use the standard calipers, but come with a bigger disc, different pads, and new mounting brackets for the standard calipers.
Does a similar kit exist for Evo's to allow us to use something like a 362mm 2-piece disc with the Brembo 4-pots?
Matt
You can get a 2 piece rota and bell for the standard setup, so you can do a trackday with the peace of mind that you aren't going to warp your standards!! (No they aren't the AP strapdrives)
I am in the process of getting a set for mine!!
Matt
I haven't heard of a kit but would be interested if you get one!
seems like a lot of work though, surely all the caliper mounts etc would need replacing?
Have you thought of just buying decent 2 pieces disks and good pads?
My performance friction set up is fantastic, can't fault it!
Can only be something like an adaptor bracketry like the other car marques have, not that big a deal really and would allow bigger brake discs like 360mm one with the mega cost
