Guest
·Wanting to move battery to boot and move fusebox to glove box,take it i need to do the following...
Run a positive cable to boot and joint to existing loom pos.(using heavy duty battery cable from demon tweeks)
pick up an earthing point in boot.
find or driill and gromit a hole through bulkhead for bat pos cable and fuse box wires(possibly behind glove box?)
splice into fuse box loom and extend wire for wire through bulkhead hole.
soldering and heatshrinking joints or using a multi connector,covering extended loom in plastic loom protector.
Other option is a battery isolation switch ,but may effect alarm unless i run a perminant feed seperately for the alarm.
Havent even looked in engine bay yet ,so any opinions help would be appreciated .
