1 - 11 of 11 Posts
Why do ball bearing turbos have lower lag? Presumably this is due to lower bearing friction. But why??
With turbos whizzing round at 150000rpm |PLS| i would have thought that the standard bearing of shafts in floating oil would have less friction than a ball baering race. Or is it the thrust bearing that is replaced by balls????
Oli,
In BB turbos, the whole sleeved centre housing is replaced with 2 ball bearings housed in fully floating cartridges.
You can also do away with the thrust bearing because you have a tight clearance between the bearing surface and the shaft and so bb turbos can take a lot more thrust load.
Andy
I have a Roller Bearing Ti-Turbo on my and it cuts in about 1500rpm:):)
I was told that it has lower bearing friction as well, when I turn my car
off you can still hear the turbo spinning for well over a minute!!!
Cool noise!:)
Tony
Duffman,
It's an E6 RS Titanium Roller Bearing Turbo, a Hybrid made for Rallying!
It was recommended by Dragon who did the High Torque 400bhp conversion on
my car:):D:DYumYum.
It kicks in so smoothly and instantly with no lag at all:)
Tony
thanks all.
They sound so good presumably the reason we don't all have them is cost?
I don't suppose there is much advatnge for racing as spool up is not so important if you are always flat out?
1 - 11 of 11 Posts
