Guest
·seeing mention in another thread of the possibility of a sports ecu for the ayc got me thinking...
firstly the ayc system appears to be getting a bad rap so first a few opionions (note this is not a defence but simply trying to sort out the facts)
1 its a traction control device
-no its not because typical 'traction control' devices reduce engine power and it doesn't
2 its not an lsd
-yes it is because when accelerating in a straight line, if excessive slip is detected on one wheel it transfers torque to the other non spining wheel thus limiting slip
3 its makes the car slower
-not necessarily because it is (up to a point which i will come to) better able to transfer power into forward motion rather than sideways motion. depending on the surface, this will generally make the car faster if goes where it is pointed rather than assing out all over the place
4 it's for less skilled drivers
-firstly it's still entirely possible to go sideways given enough power and lacking enough grip. remember it does NOT reduce engine power so by transfering torque it may be able to delay this but it can't overide the laws of physics which brings me to the most serious issue i have with it but which is not often mentioned,when it does go sideways the break away can be quite sudden and it is less 'progressive' than the mechanical arrangement. you may actually need to be a 'more skilled driver' to take an ayc car to the absolute limit and avoid spinning it
so as a compromise why not 'alter its map' so that the straight line lsd function is retained but the cornering characteristics are altered? given it's an electronic system the characteristics should be infinately variable compared to the fixed settings of the old fashioned mechanical lsd and if done correctly it should be far superior. after all you can't say that electronic engine management is bad compared to a carburator and points just because it's been mapped for economy and not power...
i soon see another debate: should i get a 'ralliart sports ecu' or 'fully mappable one'.....for the ayc
andrew
2 its not an lsd
andrew
