1 - 13 of 13 Posts
Hello. I have a JDM Lancer Evolution VI GSR, driven 145,000km. When I start car, AYC light is off. After driving ~0.2km it illuminates. Haven't noticed any torque/steering problems (would notice since It's icy af on here).
AYC pump has been upgraded by previous owner 25,000km ago including AYC fluids ofc. I heard from local Mitsubishi dealer that it is because of higher pressure, upgraded/stronger pump and that It's located higher (on trunk drivers side) causing so. But couldn't say for sure.
Car works normally and it's not causing any problems when driving, but would like to find out since I have nothing better to do. Anyone else had similiar problem?
41 is tps as said but a generic fault code
82 is pump failure, do you have any leaks? have you checked the fluid level? could be dragging in air as usually when you drive that little distance its air related and needs bleeding, or the pump has an issue internally
it cant be upgraded to run higher pressure either
Car was in was garage last day and was dry in evening. Checked for leaks, but nothing found. Fluid level was good.
who refurbished it?
Sorry for bring inactive. I was searching cars history and got the last owners for sale post/info (bought myself from dealer). He stated in selling information that It's NEW, more powerful/efficient ayc-pump.
The dealer said only that It's been tested before selling and was working perfectly despite the ayc light. That is all they had to tell.
Could The problem be air dragging in lines? If so, i'll give a try to bleed the system.
Located the source of problem. It is AYC relay. Changing it this weeks thursday when I receive replacement Part.
Update
Changed relay and changed AYC fluids and aired the system. Did a test run, no ayc light and everything was working without problems. So problem fixed. Can close this thread and thanks for the help.
1 - 13 of 13 Posts
