Guest
·When I accelerate hard with my Evo6 I get fuelcuts.
The only modifications are: Ralliart replacement air-filter, Magnex downpipe, Magnex decat and Ralliart backbox.
The boost I have peaks at 1.3 bar and then drops to 1.2 and 1.1 (standard ecu) sometimes with, mostly without fuelcut.
When it's cold outside (like now) I sometimes notice 1.4 bar(!) just before the fuelcut.
I’ve done some research and there are (at least) 2 ways to solve this problem:
1. Apexi AVCR Boost Controller, Apexi AFC Fuel Controller, Walbro Uprated Fuel Pump, FSE Fuel Regulator, ARP Bolts (this can be done f.i. by RC Developments)
2. Power Engineering can provide a new (custom-spec) ECU for 900 GBP or can modify the ECU for 550 GBP
I don’t want the ralliart ecu because It seems that the Ralliart Ecu is retarding the ignition to much at higher revs.
If I lived in the UK I would probably go for the first, because here in the Netherlands there aren’t too much experienced EVO-tuners.
For me it’s more interesting to go to PowerEngineering and let them modify my Ecu in one day, and drive back fast with no worries.
But…I have no experience with PowerEngineering.
Does anyone here on the board?, has anyone had his ecu modified bij PE?
Please advise what’s the best option for me.
Jean-Pierre
Jean-Pierre
