1 - 2 of 2 Posts
hey guys, my 7 has developed a boost issue and I thought it was a jammed dump valve so cleaned and freed that but problem still here. I disconnected the wastegate vacuum pipe from the solenoid and its getting 0.7 or 0.8 bar fine but plumbed in and set for 1.2 it gets up to 0.8 or 0.9 and flutters? basically has anyone had similar problems and what did you find was the cause?
thanks in advance!
Possibly a partially seized wastegate? Would definitely be checking all hoses and vac lines. And the one going to dump valve. Is it a recirculating one?
Sent from my SM-G935F using Tapatalk
1 - 2 of 2 Posts
