Max Power: 200 bhp @ 7000 rpm 260 bhp @ 7500 rpm
Max Torque: 165 lbsft @ 5750 rpm 200 lbs ft @ 6200 rpm
0-60 mph: 3.7 secs 3.1 secs
Max speed: 140 mph 155 mph
ENGINE
Displacement: 2261cc 2261cc
Configuration: In-line four cylinder In-line four cylinder
Number of valves: 16 16
Bore x Stroke: 87.5mm x 94mm 87.5mm x 94mm
Construction: Alloy cylinder block and head, cast crankshaft, sinter forged connecting rods, cast pistons Alloy cylinder block and head, cast crankshaft, forged connecting roads, forged Cosworth pistons
Lubrication system: Caterham dry sump with internal scavenge pump Caterham dry sump with internal scavenge pump
Camshafts: Cosworth-developed high-lift inlet and exhaust Cosworth-developed performance inlet and exhaust camshafts,
uprated valve springs
Induction system: Cosworth-developed inlet manifold and larger diameter throttle body Cosworth-developed gas flowed cylinder head, roller barrel port throttles
Exhaust: Cosworth-developed exhaust manifold, Caterham developed exhaust system Cosworth-developed exhaust manifold, Caterham developed exhaust system
Engine management: Ford “Black Oak” ECU with Cosworth-developed calibration MBE open ECU with Cosworth-developed calibration
DIMENSIONS
Wheelbase 2315mm
Front Track 1505mm
Rear track 1465mm
Overall Length 3300mm
Overall Width 1685mm
Height (hood up) 1140mm
(hood down) 1015mm
Ground Clearance 100mm
Turning Circle 11m Wheelbase 2315mm
Front Track 1505mm
Rear track 1465mm
(hood down) 1015mm
Turning Circle 11m
PRICE
(starting price)
£28,500 Self Build
£31,000 factory Build £34,000 Self Build
£36,500 factory Build
