Hope someone can help as i know just about nothing about ICE.
Want to run some components up front, some 6.5inch 2 ways at the rear and a small 8 inch sub in the boot.
The head unit is an Alpine CDA-9812RR
Right so I was going to use the head unit to run the rear 2 way speakers.
A Polk MOMO C300 amp to run the front components:
Power
Channels 2/1 (bridgeable)
Total Dynamic Power (all ch. driven) 850 watts
14.4 Volts RMS Not Bridged @ 1kHz
4 Ohms 150 watts x 2
2 Ohms 220 watts x 2
14.4 Volts RMS Bridged
4 Ohms 450 watts x 1
Electrical
Signal-to-noise (Referenced to rated power) > 105 dBA
Remote Gain 0 to -30dB
Input Impedance > 10k Ohms
Output Impedance < 0.02 Ohms
Overall Frequency Response (-3 dB Points) 10Hz - 45kHz
Protection circuitry Power and ground reversal, Thermal and Short, Current Overdraw and Low Impedance Protection with auto stand-by mode
Dimensions
Overall Dimensions (with panels) 2-1/2" H x 13" W x 9-3/4" D
(6.35cm H x 33.02cm W x 24.77cm D)
Product Weight 12.00 lbs.
Total Shipping Weight 13.50 lbs.
Filter Settings
Subsonic Filter 24dB/oct @15Hz
High Pass Filter frequency 50Hz - 250Hz
High Pass Filter slope 18dB/octave
Low Pass Filter frequency 50Hz - 250Hz
Low Pass Filter slope 18dB/octave
A Polk MOMO C500 amp to run the sub
Power
Channels 1 MonoBlock
Total Dynamic Power (all ch. driven) 975 watts
4 Ohms 350 watts x 1
2 Ohms 500 watts x 1
Electrical
Overall Frequency Response (-3 dB Points) < 10Hz to 200Hz
Dimensions
Overall Dimensions (with panels) 2-1/2" H x 11" W x 9-3/4" D
(6.35cm H x 27.94cm W x 24.77cm D)
Product Weight 10.00 lbs.
Total Shipping Weight 12.00 lbs.
Filter Settings
Subsonic Filter 24dB/Octave @ 15Hz
Low Pass Filter frequency 30Hz to 200Hz
Low Pass Filter slope 12 or 24dB/Octave
Is that all I need????
I was going to uprate the std Mitsi battery to something a little more powerfull.
Any help would be much appreciated before I go and buy this little lot!
I have asked similar questions before but this time it is defo getting bought so thought I would make sure i have it all right.
Matt
