I ran the 3 1/2" exhaust system at Donnington last October and basically was able to keep my foot to the floor throughout the pit straight without pipping the noise meter, and i believe that Donny have a noise reg of 98db.TCB said:Thanks
Have you been through many noise tests to confirm they pass ok ?
And are you running APS (or other) induction that could add to the noise level ?
Global,GlobalGB said:Hmm this APS sounds more intriguing by the second, what sort of pricing are we looking at for full APS induction, APS full system (manifold too?) and how does it compare with the HKS induction and drager kit?
It appears that APS do a manifold, but only for APS turbo.GlobalGB said:Thanks for the info Paul, I probably would not use a BOV unless I changed from a MAF sensor to a MAP sensor (mandatory if heading Motec/Autronic) and as for the intercooler would only consider if there is a more efficient one than the std mitsi intercooler which happens to very efficient probably upto 450 bhp.
Cheers for the link
Mark
So u can go down swop your APS for one of their standard systems go off an get your MOT and come back and whack the APS back on?One more thing. If anyones worried about MOT time with the 3.5" (APS didn't manufacture a cat for this due to expense), WRC hold a stock of std VIII exhausts with cat.
WOW!Mike said:i failed a sound test drive by with the 3" system at donnington, dunno how because they sound pants
