1 - 5 of 5 Posts
Discussion Starter #1
Does anyone know if the apexi power fc require's specialist mapping setting up?
Or is it just a case off plug and play and adjust using the commander.
Seen a few for evo(I-III) going cheap on ebay.
It comes pre programmed with a base map to run the car, then youll just have it remapped to suit your mods, so its important to get the right one for your car and get the right base map.
theres only one problems, ive looked on the US and JP apexi site and i cant find one listed for the early evos, actually nothing before a E5, i could be wrong thou, it just could be due to its age and demand, they no longer list them, but you may be able to find one somewhere or request one from an authorised dealer.
Discussion Starter #4
They dont list them for the early cars,but they are available on special order(according too these guys selling them).
so it comes with a base map to run the car and then further mapping needs to be done can this be done by driving around and adjusting the commander or does it need to go on the rollers.
rollers would be far easier, unless whoevers doing it is competant enoguh to do it on the move, but youll need a wideband O2 sensor aswell, and unless its a mobile unit, its the roller option.
1 - 5 of 5 Posts
