Guest
·hi there ryan
i think you are a bit harsh on andrew as i am sure he did not mean to offend you in any way. probably getting a bit frustrated with people dismissing link ecu, but you have hit the nail on the head. the problem with the link ecu in this country is that there is only one official tuner and he is too involved with scoobies. also it is more a part time than a full time job for BRD. few points i would like to mention though.
THERE IS NOTHING power FC can do that the link won't be able to manage. igntion, boost, fueling, the link can also get you launch control or anti lag ( i don't think the power FC can do that? ).
i have seen the power FC on 2 500bhp skyline and had a look at the commandor ( hand controller) it is an impressive piece of kit. but it is ALOT more difficult to tune than the link. the ZONE ( tuning points ) are displayed in little dashs (- ) accross a x and y grid, with the loading points for the map ( ie boost levels ) are displayed in numbers 1,2,3 etc.. that does not make sense to me!! so it will take a while to find your way around it compared to link, motec, gems etc.. as they all show you clearly the RPM, IGNITION at the crank, fueling and the related zones. this obviously does not make any difference if all the apexi stuff uses the same loading axis for tuning, like the boost and the fuel computer. that will make RC the most qualified to tune it.
I bet you not that many poeple on this board know how much it cost to buy the leads and software you need to hook it up to a lap top
now the link pros and cons.
only one tuning company. it is a lot easier to tune by individual like us. alot easier to understand. mapping maybe tricky to the un intiated but changing couple of zones by a point or two OR maybe couple of % ( depending on the system used) to add more fuel at the top end after fitting a bigger exhuast etc is very easy. IT CAN BE TUNED by a tunning module which costs £100 instead of 350£|PLS|vat!! it can provide you with data logging straight to your lap top. lap top connection in the form or a serial link will in cost you £40-50 something like that. you can obviously see all the engine parameters that the power fc will show you. actually if you think about it all the ecus will show you the exact same engine parameters. if there is a sensor for it the ecu will pick it up.
what the power fc and link ecu have in common is they are both car specific, if you buy them for an evo6 you will have to sell them on if you change cars!!
NOW full ecus like the gems and motec etc.. ARE more difficult to tune because they are not car specific ( which is also an advantage) obvioulsy alot of the car parameters specific to certain are not automatically stored in. etc.. they how will porovide you with all the functions of the link, plus anti lag, launch control, and the ablility to add modules ( water injection) extra sensors if you want etc... and also if you sell your car you can take them with you to another car. which makes sense on the long term ( i know for a fact over the next 5-10 years i will be buying perfromance cars
motec don't believe in knock control and i have been in car being mapped with motec they guy waited until you actually heard knock inside the cabin before retarting the igintion. OK they use very complex fueling but still what happen when you get a bad batch of fuel? or get a blocked injector?. i feel safer knowing that eh ecu will retard the timing if it senses trouble.
gems has knock control. is it will be my choice when i change my ecu. I WOULD HAVE loved to get link but they have not made one for the EVO 7 yet
i have contacted them few times so far. actually i am in contact with ralliart NZ just now so something interesting may be developing in the pipe line but i have to wait and see
actually the only difference between all the above mentioned ecu is the processor speeds. does any one know what is the processor speed for the power FC? this is the only area the link is lagging behind the rest of the ecus.
one more thing. ALL ECUS will achieve almost identical power and torque out put if they are mapped the same way by the same person. so it does not really matter what you go for!
i am sure i have missed few points but i can't remember just now
