I bought a set of AP 6 pots (used).
On the bottom side of the caliper its engraved CP5570, but on the inside CP5555.
So which ones are they?:confused:
They came off a VI but both fits a VI. Was confuses me is that the caliper is ingraved with CP5570 on one side and with CP5555 on the inner side???
you are probably looking at the casting numbers for the mounting side and the cover side. not the kitr numbers
Jez
How thick are the discs?
AFAIK for an Evo at least, the CP5570 caliper uses a 28mm disc but the CP5555 uses a 32mm disc.
Jez will confirm if I am right ot wrong?
Stevie
