1 - 5 of 5 Posts
On the AP website they list a kit, part no. CP5555 - 1035. This has a 6 pot caliper with 362mm grooved disk.
I keep reading that this is not available, although I have seen it on Extremes. If it is a BR Development special, why is it listed on the AP site?
Does anybody know?
Thanks in advance :)
I asked several technical and sales people at AP and they said the 362mm
disc is only available for the evo7.
Also, ive heard the 6pot 330mm setup gives almost identical performance to the
6pot 362mm setup, yet the 362mm discs is a lot heavier. Something to consider,
size isnt everything http://www.lancerregister.com/graphics/Wilk.gif border|EQU| 0 align|EQU| middle >
Justin
Thanks Justin, lucky I have a 7 then ;)
I will research the weight issue. I remember a thread previously that discussed how much performance should increase with disk size and will try to find that as well.
Simon
They did release the kit for the 7 a few months ago, that is a proper AP part. The 6 362mm kit was the special. It was probably me confusing you :D
Mark Shead has 362mm 6 pots on his E6, fitted them ages ago. Give him a call if you need info.
Mobile 07768 356204
Kevin
1 - 5 of 5 Posts
