Guest
·Where have you fitted the compression tank in the front? Right now mine is fitted to the strutbrace, but it makes quite loud noises when the gas flows into the tank. I think the strutbrace amplifies the vibrations of the tank. It's not that bad, but if anyone has a solution it would be appreciated. Also, what settings do you run? I'm running FRONT: Low speed bump 6; High speed bump 12; Rebound 12
REAR: Low speed bump 6; High speed bump 14; Rebound 14.
