acting daft since 1969
if its not getting a feed the ecu will just dump in fuel to try and warm it up wont it
water temp is one of the very few defo things an ECU needs to function properly i believe
i expect so, its only for a few days till i get a new 1, i can run with it connected, in fact i think when cold the car wont start without it, but the car at the moment runs better with it disconnected
Stu
its defo duff then stu ,it wont run properly warm as its not getting any info on as and when to advance the map to alter the fueling
it may not start with it disconnected as it needs a connection but as it runs with it it may drop in to some form of limp mode when it sees theres an issue
The ecu will just set a given temp and fuel to that, so yeh, it might run rich for a while.
i'll probably reconnect it until the new one comes then, it will drive, its just a pig to drive in traffic
its not showing a fault in datalogging, so i dont even know for sure if it is causing the problem, or by disconnecting it and bringing on the EML, is giving a set of default settings, 1 of them masking the missfire
Stu
