1 - 20 of 25 Posts
I could get from an Evo 8MR if I were to:
1) Change exhaust to 3'' turbo back Miltek with 200cell Cat
2) Walbro fuel pump
3) Ecutek remap or other aftermarket ECU
Thanks,
Socrates
what power would you like.
You can what ever you want providing you £££££££
I would be more than happy with 370+ to the extent that it will be reliable :)
I thought that the exhaust and the fuel pump is the cheapest & reliable way to get me there.
What do you think?
where are you based? it is worth asking your tuner, as ultimately they are the onew working on the car. But up to 400 is possible on an 8 MR at stg one.
390-400 with decat and 3 port solenoid. Not sure whether the 200 cel will reduce power slightly
Non of those mods will add power unless you turn up the boost as well.
Super Moderator
Jesus built my car
Well you wouldn't fit three port boost solenoid if it wasn't going to be increased:shake:
Technically you could. The standard solenoid design isn't that great at controlling boost and reacting to changes in boost. A 3 port design is better in this regard and as well as being able to hold more boost (what you may need if upping the boost) it also gives you faster spool, better turbo response and more accurate boost control. If you were a purist you could fit one and keep the boost standard to still gain those advantages even if keeping the power the same.
http://www.lancerregister.com/showthread.php?p=4582184#post4582184
Yeah but the OP is clearly after 'more power'.. what tuner isn't gonna make his wish come true with 1.8 bar? lol
Super Moderator
Jesus built my car
Agreed, I was just explaining why foreskin fred was technically correct :D
Pedantic cnúút indeed :crackup:
yet kinda correct :rolleyes::mhihi:
@OP , youve been on here since 2005 ...yet still non the wiser about :mitsi::crackup:.......
Another one for X 360 :
C-Tec S-Ti
C-Tec decat(silenced)
C-Tec downpipe
ETS intake
3 port
1 - 20 of 25 Posts
