1 - 20 of 20 Posts
that have daywork rates for
Bricklayer
Joiner
Roof Tiler
Plasterer
Labourer
and rates for supply and lay
100mm Blockwork per M2
Concrete roof tiles per M2
Roughcasting to houses per M2;)
Depends where you are in the country, and how large the areas/quantities are
In Surrey the minimum I have paid is;
£160/day bricklayer
£70/day labourer
£160/day carpenter
£270/day plasterer & labourer
Never had a roofer on daywork, they are not cheap. I would get one on a fixed price, as you can never see what is going on up there!
Paid £16-18/m2 for labour only blockwork
Block prices vary a lot, some are £9/m2 others are £18/m2. Speak to a merchant for supply price, likewise for roof tiles
Not sure about the roughcasting/pebbledash, although i have paid £28/m2 for external rendering
Hope this helps
In Surrey / London the minimum I have paid is;
£160/day bricklayer
£70/day labourer
£160/day carpenter
Hope this helps
they sound about right but london rates add bout 20 2 25 more and us sparks local 240 up town 260
kev
£160/day bricklayer
£70/day labourer
£160/day carpenter
Hope this helps
kev
i'm a carpenter and there is no way i would work for £160, £200 is the minimum and i haven't had any problems getting that for quite a few years now. saying that i am a roofing carpenter and you would be supprised at the amount of carpenters who haven't got a clue when they are faced with a big cut and pitch traditional roof, that's probably why i earn a bit extra.
labour on blockwork is £10 m2 down my way, might be higher tho as im a mason and £130 a day is the goin rate down here
Banned
Im a roofing contractor and im £200(plus labours) a day to builders and in the private sector its £300 but then i do about twice as much work as most other roofers in a day!
£160/day bricklayer
£70/day labourer
£160/day carpenter
Thats quite a bit out, thats around the going rate for blokes on site ie large scale commercial sites in and around the M25 area working on Wimpey homes, barratts etc, as a painter myself doing private work I charge no less than £200 and thats reasonably cheap, all depends on what's involved etc.
I can earn 200-250 + on site, just depends if the works easy or a pain in the head and if i can be bothered to pull my finger out which doesn't happen that often as it's a kack job i do unfortunately.
Ditto :smthumbup Im a time served carpenter/joiner and you would be suprised how many chippys can not cut and pitch a traditional roof .
Billy
I don't blame you guys for charging a decent wedge but I can get decent brickies, chippies, plasterers and roofers for £100-140 per day, if you shop around and get people recommended there are good guys out there charging sensible amounts.
im a stonemason and if im cladding a house with trimmed grannite stone then its 50 quid a square metre, its about 40 quid with field stone.
I normally put about 5 metres in on a good day.
1 - 20 of 20 Posts
