*SOLD*
AMS Harness bar, used but as new, complete with all the fittings, instructions, even the stickers!
This is a simple item to fit but makes the enjoyment of trackdays etc better because you are held in the seat a lot firmer with a full harness.
When fitting it is necessary to cut the B pillar trims, however I'll include two pre cut trims making the fitting even more simple and meaning you can keep your trims intact if you want to refit them later :smthumbup
Looking for £170 collected from Leeds.
Contact by PM or sidermlr at gmail.com
The AMS EVO X Harness Bar was developed to not only perform as designed, but to keep the functionality of your stock or aftermarket seats as well. All too often harness bars prevent seat movement and stock seat belt functionality. With our bar you will not only be able to maintain 100% use of the factory seat belts, but you can also maintain almost FULL front seats adjustability.
Features
• Powder coated for a subtle and clean appearance
• Harness guides attached to the bar to keep the harness' in place
• Height adjustment to place the bar to the drivers specification
• Designed to suit most popular 4 and 5 point harness'
• No cutting required - Direct bolt on
• Jig welded
• CNC'd bar ends
• Includes harness guides on bar
• Hardware included
Specifications
• .120 thick tubing
• Grade 8 hardware
Applications
• Mitsubishi Evolution X
• Fits all USDM, JDM and European Models
Features
• Jig welded
• CNC'd bar ends
• Hardware included
Specifications
• .120 thick tubing
• Grade 8 hardware
Applications
