1 - 10 of 10 Posts
ok I'm gonna let my tuner active the als on my autronic ecu with a switch
but my question is anyone on here that killed a turbo with it using it 2 much?
I have ALS and Autronics..
I try too use mine as often as poss.. :naughty: :lol:
Prolonged use will kill turbo's, and cause high underbonnet temps.
:smthumbup
sweet can't wait 4 it won't be using it 2 much and not 2 long either
thanks 4 the relpy's
I don't use mine much, might try it for a run on the 30-130 to see if it helps, but doubt it.
Just use in short burst of no more than 2 mins is my advice, just to be on the safe side.
Also with autronic, mine takes a minute or two to reduce the revs after its turned off.
1 - 10 of 10 Posts
