1 - 10 of 10 Posts
Just fitted a set of HSD coilovers to my evo 9 today, going to get it setup on a hunter system, im running 9x18 rotas with 255 tyres, whats best settings to have on this, car is mainly road car but the odd track day?
you can add some camber say 1.5 f 1.2r but try and keep toe 0 all round that works for me if you toe out on the front it will turn better but ware the tires real fast .
You may want to put a bit of toe in on the rear otherwise it could make the back end a bit loose. 1.0 - 1.5 degrees should do it.
1 - 10 of 10 Posts
