1 - 15 of 15 Posts
when i press the fob to set the alarm it gives four beeps(which i think means the alarm is set), then maybe 5 mins later the alarm goes off. just replaced one off the door sensors as i thought this was the problem:wallbang:. any ideas:smthumbup
What make and model of alarm do you have installed fella? :) from here i may well be able to offer some help :smthumbup
I think four beeps is reading a door, boot, bonnet still open.
just remembered from somewhere about the bonnet switch. open the bonnet and push it down, then try locking.
If you are still having probles give me a ring mate
Ian 07774 446402 Leeds
if the interior light goes on when you open a door, and off when you close them its not 1 of the 4 door sensors
chances are it will be the bonnet sensor, with the bonnet up, look along the front for the sensor/plunger, and there should be 1 wire connected underneath it, if you remove this wire (and make sure it doesn't earth on anything) the try the alarm again
Stu
I've had 2 instances like this, one was I left interior light on, and the other was the bonnet switch had bent downwards and wasn't making contact
just tried this and didnt get the four beeps, car gave 2 flashes. then put the bonnet down and the four beeps agen. so ive just pulled the sensor up abit and i get two flashes now. is this whats supposed to happen:confused:
before when you had the 4 beeps, if you left the alarm armed, would the alarm eventually sound?
i'd expect it should, and if now it doesn't i'd guess it is correct
Easy test, shut everything up, alarm the car, leave it for a few minutes then unlock the door with the key and open it, see if the alarm sounds
Stu
2 beeps good, four beeps bad.
well since i got the car its always beeped 4 times when locking, and never had the problem with the alarm goin off until recently. alarm doesnt seem to be going off anymore but will try what you suggest tomorrow
Stu
right ive done what you said and also had to bend the sensor back up and everything seems to be working ok now.
cheers for the help guys:smthumbup
1 - 15 of 15 Posts
