1 - 8 of 8 Posts
When I was looking into a brand for gauges it seemed that Defi was recommended by the vast majority of people.
I have a Defi BF Amber 60mm Boost gauge and I'll shortly be getting a matching Oil temp gauge and A-pillar dual gauge holder.
A quick google seems to show that Defi do AFR gauges too.
I got mine from seller "fusion-r" on ebay and I know someone else from MLR who got some Defi kit from him too.
I've been wondering too about AFR.
This appears to be a popular company:
http://www.innovatemotorsports.com/products.php
And then here too:
http://www.zeitronix.com/
It's confusing for me because there is really expensive AFR like Autronic Exhaust Gas Analyzer (~$1600) and then relatively cheap ones. Then you have to understand the probes. Then there is narrowband and wideband. Quite confusing.
I *think* my understanding is something like the Innovate product is a pretty good bit of kit. Maybe not for professional tuning, but at least for keeping an eye on things.
:confused:
innovate will do you.
even the cheap widebands can be used professionally and tend to do an excellent job.
Just make sure its a true wideband, ie. 5 wire. the 4 wires and sometimes 3 wire probes are a heated narrowband which does not work the same way and does not give a true wideband response.
Personally, unless you are into mapping, I am not convinced people understand what they are doing on the fly, so they tend to be a waste of space.
for gauges, I would far rather have a neat PSI3 monitor sitting above or below the stereo.
I'm gonna ring Innovate at some point because I'm hoping their product can connect to my SM4 and perhaps I could do some logging and stuff.
Remind me about the PSI3 again? It's a little display device that connects up to the standard ECU right?
1 - 8 of 8 Posts
