1 - 9 of 9 Posts
i would like some advise on what strength spring would be best to use in a forge actuator, the car (evo 6) only has a filter and decat at the moment but im looking at getting it re-mapped at a later date with a gizzmo boost controller,
would it be better fitting a softer spring now then changing to a stiffer spring just before the re-map
cheers tony
cheers gray, there is a green spring (5-10 psi) fitted in the actuator and i got a yellow one (9-15 psi) as well, would the yellow one be ok now and after the re-map or would it pay me to get the stronger blue one (14-18 psi)
cheers gray, i will fit the yellow spring in tomorrow as that is enough boost until i get it re-mapped,
can i leave that spring in thou after the re-map and be able to run about 1.5 bar with a boost controller
1 - 9 of 9 Posts
