1 - 18 of 18 Posts
hi grey had to sign in with my other user lol still havent sorted out the low boost thing was talkin to ant at indiego today he said my preload mite be the prob and to set it higher
it holds it well stu and dont make no where near that pressure
if you have a 1.5 bar actuator, and you are not reaching 1.5 bar, then you effectively have no boost control, the actuator will always keep the wastegate closed
if you are not reaching 1.5 bar i'd guess you have a boost leak, and in time your turbo will fail. If you are reaching 1.5 bar, then it will be your engine that fails
Your car as standard should be peaking at 1.0 bar max, probably more like 0.9 bar
Stu
doesn't sound good, might be worth getting a trained eye to have a look over it for you
If you are going to be working on, and modding turbo's, you could really do with a boost guage to tell you whats going on
Either way, be very wary of putting too much boost through an engine, especially a 4 engine, as you could end up looking for a new engine too :(
Stu
1 - 18 of 18 Posts
