1 - 5 of 5 Posts
Discussion Starter #1
My e4's abs light is staying on constantly. Any ideas before i have to go to mitsubishi and get my bottom smacked!!!????
Probably an ABS sensor or ring fault. First of all check the ABS rings on the ends of the driveshafts are all intact and not mssing any teeth.
Discussion Starter #3
abs light on
Cheers mate will check em out.
Also on a slightly different note im getting a knocking noise sounds like cv joint from nsr corner any ideas?
Could be all the same problem. Make sure the ring is actually on the driveshaft and not loose.
Discussion Starter #5
the rings are attached and all teeth appear to be there, there is however more movement in ns driveshaft than os??
1 - 5 of 5 Posts
