1 - 3 of 3 Posts
Hiya All
I am about to get (sign for in the next 48 hours) a 2005 Evo8 260
Anything i need to be aware of ?
Anyhting i need to look out for ?
Any recall work that needs doing ?
Any advice will be appreciated
Cheers and thanks in advance
Yep - make sure the clutch's not on the way out, it'll be making noises if it is, cbeck the alignment of the wheels since because of the stiff ride it's hard to tell they're not aligned till you're going very very fast, check the 5-speed gearbox is perfectly smooth - it should be! Some of these problems may only appear after a week, so check with whoever you're buying from as to what happens if they do!
1 - 3 of 3 Posts
