ARP2000 Head Studs Evo 1-9, done 10K miles, no issues before removal: £50.00
ARP200 Main Studs Evo 1-9, done 10K miles, no issues before removal: £40.00
4G63 underside piston oil squirters (includes bolts): £20.00
Manley 150mm H Section con-rods – Done circa 10K with no issues. These will come with a free set of standard Mahle Evo 9 pistons (85.5mm). The reason the pistons are free is because the small end collar appears to have been machined incorrectly… I say this because the small end came loose and damaged the bore in my engine! You might be able to re-use the pistons if it was re-machined, but I cant say for sure.. £100.00
Bridgeway 156mm H Section Rods (600bhp rated) with CP Pistons (85.5mm) 9:1 compression. The pistons and rods have done running in mileage only. Might suit someone doing a re-build and wants to convert to a long rod: £300.00
Evo 9 Wheels with 245/40 Khumho V700 tyres (supersoft compound). Wheels are all straight but do have a bit of kerb rash and a few marks as they were used as track wheels. Still very presentable mind! All tyres have circa 3/4mm (these only come with 5.5mm when new): £350.00
Exedy HD Twin Plate Clutch – Plates need replacing: £100.00
Evo 8 water pump: £30.00
Evo 9 engine mount, no issues, selling as I upgraded: £30.00
Evo 9 coil packs (red tips), upgraded to COP: £60.00
Brembo rear calipers, good working condition: £25.00
Open to sensible offers on most parts..
All prices are plus postage and collection only on the wheels.
Pictures available via E-mail or Whatsapp. PM for details...
Parts located in Bedfordshire.
Cheers Gary
Cheers Gary
