Guest
·2 issues for your edification (or otherwise):-
AYC Fluid Change
My TME was in for service today. I spoke with mechanic who was dropping me off at work and he said that he had noted that the AYC fliud was always clear when you got it out by just draining out of the reservior. It was not until they put the MUT11 onto it and turned the steering wheel to pump out the AYC fluid that they saw the horrible black burnt fluid coming out. He reckoned that you'd be alright just draining it for a couple of times but that you should pump it out every 3rd/4th change. He also said they are still using the pucker mitsi AYC fluid as they have loads of it but will use Dexron 3 when they run out. Apparently when pumped out the fliud comes out very fast so make sure the drain hose is on tight!
Rear Suspension cracks
When i was at the rally prep place who did my decat the chap there had an E6 being prepared. He showed me how the rear upper suspension wishbone had cracked along the casting mark around one of the rubber bushes where they fix onto the strut. The chappy whose car it was didn't realise until the car was stripped down. As the crack is facing into the body of the car it would be very difficult to see when on the car. There is a 6 week delivery on these bits.
AYC Fluid Change
